Active-X to Siemens S7 PLC
Hi
I am looking for a Active-X that can communications to a Siemens S7 PLC connectet with at Tcp/Ip (Ethernet)
I will like to use at CP243-1 Card to a S7-300 serie.
Can you help me with a link, or you own Active-X ??
Today I am using In-gear`s active-X to Allan Bradley Plc`s
and it is working perfect!
Regard Arne
RE: Active-X to Siemens S7 PLC
Hej Arne,
B-plus gmbh has an activeX for S7, but it is not cheap - 2500€.
go to www.b-plus.com
Let me hear how good/bad this product is.
Jesper M. Pedersen :)
Hej Jesper
I think that 2500Euro is to most.
Do you know the protocol for S7/IP (S7-300) Kummunication ?
I will then make my own Active-X, I have allready make to a Omron CJ1 CPU (Ethernet card EN11)
Arne Vestergård hansen
Hej Jesper
Kan du ringe på tlf 20319428
Hvis du kender protokolen for Siemens S7 Ethernet
kummunication, eller et sted hvor jeg kan finde flere
informationer.
Jeg har Siemens Net Cd-rom, den beskriver dog ikke retgodt
hvordan protokolen er opbygget.
MVH Arne
Hej Arne,
I don't know very much about the various S7 protocols, only from a users point of view.
Siemens probably keeps the specifications to themselves, as they dont want others to make competing products to their Simatic Computing software.
But there are a few who make DLL type libraries (not ActiveX) for S7, and they are not all so expensive:
www.deltalogic.de (MPI/Profibus/Ethernet) approx 2000~3000€
www.mhj-software.de/mpi.htm (MPI) approx 900€
www.process-informatik.de (MPI/Ethernet) approx 2000~3000€
