Make line type
Make line type
A line type like this" -CW-" was made for one of the layer w/express tools of ACAD 2004. The program saved it as a file and loaded it in the layer property. Every detail in that one layer appeared proper however when a line was drawn w/ that layer current we got only a straight line w.o the CW's. We zoomed in the line several times to check for the lettering. We repeated the programming two other times w/ no change in our result.
To be sure that the steps were correct I opened a new file and created that line type w/ no prolblem.
Another thing peculiar to the file w/ the incorrect linetype is when I tried to change color of any line, a series of flashing color palettes would instantaneously appear and disappear. Upon opening the layer manager w/ the pointing arrow on the right side of the layer box, all layer color selection would appear "greyed out" . Also at about one third of the drawing disappeared a little earlier during the initial attempt at creating the linetype mentioned above.
Any suggestion since a lot of time was spent by our ACAD drafter.
intothen unsed t The com
RE: Make line type
how is the code of Your linetype exactly?
I suppose, there's a collision between the font of the linetype and the textstyle.
Did You try to make a shape?
Lothar
RE: Make line type
Try creating the new linetype in the drawing thay you are having problems with.
Bird...
RE: Make line type
RE: Make line type
