resaving a file
resaving a file
Q1 When saving a certain .dft files especially to .dwg a message appears "cannot save file you may not have write-access for the file or directory"
What is the cause of this?
Q2 In the assembly environment after editing a part,I want to close and return,I click the file button and Solid Edge crashes. Could someone help?
RE: resaving a file
--Scott
For some pleasure reading, the Round Table recommends FAQ731-376
RE: resaving a file
Opened a parasolid file in SE 14 and trying to save as part file,it gives a message.. "Cannot save file, you may not have write-access for the file or directory"
Any solutions..
RE: resaving a file
RE: resaving a file
--Scott
RE: resaving a file
RE: resaving a file
I get the same error when trying to save imported customer files that I forgot to remove the read only permissions from.
RE: resaving a file
It might have something to do with the windows-setup (NT4 we used), but we got over it by installing V12 in the end.
Pekelder
RE: resaving a file
RE: resaving a file
locally it works but netw0rk no
no slash or special caracter in name
caus ei tested it by simply using 1.par
