Exporting From Excell to AutoCad 14
I have three columns of data that I would like to export into certain fields of an attribute. For example I would like the part number from the Excel form exported to the part number of the block of the drawing. I would like this to continue for as many blocks as I have rows with a number other then 0 in the quantity column.
Thank you for help in advance
BudMan38
RE: Exporting From Excell to AutoCad 14
Hi Budman,
I just suggested CADminer to a similar problem...
Basically, CADminer is a CAD information-mining tool which has a relational database where you can link/import info. from a spreadsheet and annotate your drawing near the selected entities. So I think the program may work for what you want it to for the blocks. I'm a big fan of it for other reasons.
