How to use Power Input without "c:" command
I know how to use Search (Ctrl + f) function and I seldom use Power Input mode but just out of curiosity, is there a way I can use it without typing "c:"? For example, in order to make a pad, I'd like to type "pad" in power input window instead of "c:pad".
Thanks and have a great day!
beenson
beenson
RE: How to use Power Input without "c:" command
Why don't you use accelerator keys?
This is the most simpliest way to acces different commands from keyboard. Go to Tools>Options>Commands.
In the left window go to All commands. In the right window select which command you want. Under this window you have a Show properties tab. Push the "button" and create your own accelerator key.
Fernando
beenson
