Solid Chemical Reactions Reference???
Greetings,
Is there a handy reference book that can be used in determining solid particle to particle reactions?
We mill fine powders and have seen some chemical to chemical reactions in our blending chamber.  Because the particle size is small, any reactions that may occur are only increase due to the available surface area.
Any suggestions?
Kaos1
RE: Solid Chemical Reactions Reference???
Greetings,
I am reposting this question.  Any takers?
Solid-Solid Reactions References?
