Flow restrictors on a Chiller
In our application we have (2) chillers; we are checking flows on the condensor side out to the cooling tower.
During testing of a bypass valve, we saw the flow go above 2000gpm although the chillers have 1200gpm flow restrictors on them. Pressures were not abnormally high (38psi).
I am perplexed as the function/design of flow restrictors, and appreciate anybody's information.
Thanks!
Brad
Thanks!
Brad
RE: Flow restrictors on a Chiller
Some of the flow restrictors I saw, work on differential pressure and are designed for some initial pressures. Total pressure drop estimation for your system seems to be higher than what exactly is (because your pumps are pumping more fluid). This may lead to malfunctioning of the flow controllers, of the type which I referred above.
