O-Ring Problem
O-Ring Problem
I have some problem for O-ring seal.
It used under condition syntetic oil and high temperature.I found it like a mud or soming like that.
my quesion is what happen ?
RE: O-Ring Problem
RE: O-Ring Problem
RE: O-Ring Problem
RE: O-Ring Problem
RE: O-Ring Problem
I used it for Gas Turbine, material is Viton ,Temperatur about 180 C.
RE: O-Ring Problem
RE: O-Ring Problem
http://www.polymersealing.us/wlb_global.htm?wlb=17
RE: O-Ring Problem
www.rampf-resins.com
Good Luck!
Roger
RE: O-Ring Problem
RE: O-Ring Problem
try this, good luck
siddik
