PID control using Micrologix 1000
I have a refrigeration project that requires temperature control using PID and a Micrologix 1000. Does anybody know if there is somewhere I can obtain the ladder logic to create a PID algorthim in the Micrologix 1000.
RE: PID control using Micrologix 1000
How you will perform the P (proportional) part of regulation?
I have been thinking about this project and ahve decided it only requires the solenoid to have "on off" control with a differential.
For future reference do you know of if there is a PID programme for the Micrologix 1000.
http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/0/03419BCE8516F91785256AFB00725563?OpenDocument
If you search in the RA Knowledgebase you may find
other technotes reagrding Micrologix and PID.
Christian
I will keep looking
Martyn
