Aluminum die casting material selection
I am currently designing a throttle body for aftermarket EFI systems. Before, all our parts were sand cast A356. Now, we are talking about a move to die cast. I realize that a lot of changes will need to be made, but I have a more fundamental question: which alloy should I use?
I did a search on matweb, which produced 15 possibilities. I also did some more general searches, and A380, 384, and 390 seem like some common numbers. However, "common numbers" is not exactly a basis for material selection.
Stresses are for the most part low, the only stressed area is the flange, and ours is pretty thick so stress is really not even design criteria. Thermal cycling is typical underhood environment (WORST case that OEM's design for would be -40C to 80C). I am most concerned about ease of casting, low porosity (it is a throttle body injection system, so fuel will be present in the part), and decent machining. Thanks
RE: Aluminum die casting material selection
Good luck!
Lee
