Anchor Bolt Proof Load Tests
I have existing epoxy anchor bolts embedded in a slab with a dbl wood bearing plate on it.  Can anyone recommend or point me in the right direction for a proof load testing procedure for these bolts?
Drew
RE: Anchor Bolt Proof Load Tests
ASTM E1512 is one such method
