Importing ArcView shp file into AutoCADMap
Sirs,
This is regarding importing of an ArcView shapefile into AutoCADMap software.While importing,in the Import Data Options dialog box,Import Data Elements has been specified (I do not have SQL Server Connection).A MS Access datatable has been configured and attached,but the database table is not getting transfered.
Please advice me the EXACT PROCEDURE TO IMPORT ARCVIEW SHAPEFILE INTO AUTOCAD MAP ALONG WITH THE DATA AND THE LINKS.
Thank you
Thank you
RE: Importing ArcView shp file into AutoCADMap
I am using AutodeskMap2002 and AutoCADMap2000
