military tank loading
Where can I find data for military tanks loads ?. I am interested in loads on buried pipelines.
Brian
RE: military tank loading
try Janes
TTFN
Rule of thumb when I was in a combat engineer was one ton per square foot ground pressure.
Try looking through the Army Corps of Engineers Website www/usace.army.mil/
They have a lot of technical publications available, and somewhere in there should be the answer you need.
"alternative loading"
As KThompson said, USACE is your best bet. I have a FM (Field Maunal) that has hundreds of pages of appendicees for EAl's and other data of about every military aircraft, tank, vehichle, railcars with 35mm guns mounted on them, etc. I don't have the manual in reach at the moment, but I know the name is something along the lines of "Highway Design in the Theater of Operations".
GL
-Bob
