HELP - draw dimension & change layer in one command
I dont use macros, my screen is quite minimalist, no scroll bars, 3 macros, and the one layer macro plus the pull down tabs. As all my comands are shortcut/keyboard based.
Is there any way to get it so if i tpye " DS " my short cut for dimstraight. To change it to a dimmension layer then change back once i have completed the command.
The dimension style manager will alow you to set it to colors, line weights etc but not to a layer.
Or will i need to create a lisp file and control it via " DS " ????
RE: HELP - draw dimension & change layer in one command
http://www.spaug.org/LISP_Index01.Html
Not only works on dimensions, but hatch and text also.
Flores
when you enter any hatch, text or dim command it changes current layer then chanegs back to previuos when complete
http://www.afralisp.com/vbaa/drawman.htm
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
