off-form concrete surface rectification
Hi all,
I'm working on a building which has, as its major structural and architectural feature, off-form concrete wall. The walls were constructed using 1.2m x 2.4m marine ply formwork and grade 30 concrete. My main problem is that when some of the form work were taken off, they were some surfaces which were not acceptable. The contractor attempted to rectify this by applying skim coat on these areas. Unfortunately this create patches on these panels.
My questions:- (1) is there anything I can apply to the surface to hide these patches? (2)or anything I can do short of hacking the surface again.
don allan
don allan
RE: off-form concrete surface rectification
To answer your question, I do not know of any patching that would still produce an acceptable finish after years of outdoor weathering. The only solution is to break down and start again, unless an alternative finish such as a cement based paint could be agreed for use on the entire wall.
I however have been advised to use KEIM Concretal paint. What do you think?
