Directional Lighting Problem
I'm having trouble setting the ambient color code for Directional2 in a macro. The color code I want is 12615808 (Red 128, Grn 128, Blu 192). The macro that folows works but does not change the Directional2 ambient color. Any help?
Code:
'Clr-DyeBlack.swb - 08/13/03 by [Me]
'Changes the part color, ambience, and directional lighting attributes
'to anodized dye black.
'1. Ensure a part is open before running macro.
'2. Add Directional2 lighting if it does not already exist.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim PropertyArray(9) As Double
Const swDocPART = 1
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
'Ensure a part is open
If Part Is Nothing Or (Part.GetType <> swDocPART) Then
    MsgBox ("A Part must be open to run this macro.")
    End
End If
'Assign values for the color
PropertyArray(0) = 75 / 255 'Red
PropertyArray(1) = 75 / 255 'Green
PropertyArray(2) = 75 / 255 'Blue
'Assign values for the advanced properties
PropertyArray(3) = 10 / 10  'Ambient
PropertyArray(4) = 7.9 / 10 'Diffuse
PropertyArray(5) = 8.85 / 10 'Specularity
PropertyArray(6) = 2 / 10  'Shininess
PropertyArray(7) = 0 / 10 'Transparency
PropertyArray(8) = 2 / 10 'Emission
'Set Ambient lighting
Part.SetLightSourcePropertyValuesVB "Ambient", _
 1, 1, 16777215, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.29, 0, 0, 0
Part.LockLightToModel 0, False
'Set Directional1 lighting
Part.SetLightSourcePropertyValuesVB "Direction1", _
 4, 0.45, 16777215, 1, -2.5, 2.5, 7.5, 0, 0, 0, 0, 0, 0, 0, 0.2, 0.69, 0, 0
Part.LockLightToModel 1, False
'Set Directional2 lighting (must exist first)
Part.SetLightSourcePropertyValuesVB "Direction2", _
 4, 0.88, 12615808, 1, 1.70132, -0.270355, -0.180017, 0, 0, 0, 0, 0, 0, 0, 0.13, 0.85, 0, 0
Part.LockLightToModel 2, False
'Change the model values
varArray = PropertyArray
Part.MaterialPropertyValues = varArray
'Redraw the current graphics to display changed color
Part.GraphicsRedraw
'Clean up
Set Part = Nothing
Set swApp = Nothing
End Sub
