Improved OpenGL performance
Hello all, I just found this Forum and this tip from another Forum and thought I would spread the word.
If you are having troubles with rendering large assemblies, and you are on Win NT/2000 and have an OpenGL graphics card, try this:
With no drawings, parts or assemblies open, go to Tool/Options/Performance and uncheck the "Use Software OpenGL" option.
With this turned off, I have noticed a considerable improvement in performance.  Please let me know if you have had the same results as I have.  I plan on being active on these Forums.
RE: Improved OpenGL performance
Hello all,
I replied to the last forum that you mentioned (comp.cad.solidworks). I found this option to be fabulous. I love the performance increase that I have received from unchecking this option. I have large assemblies, deeply in-contexted and anything that makes this kind of performance increase gives me a big smile.
<Quoted from ed at comp.cad.solidworks> <2001 Performance boost>
That option is meant to get rid of the video card hardware acceleration. It uses software/and system's main CPU to do the job instead, hence major performance difference. If a crash occurs, try everything again with it "enabled". It eliminates SW bug issue and points the finger at the card.
Scott Baugh, CSWP
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
Thanks MadMan...
We currently have only 1 machine running Win2K (it seems my 98SE machine is automatically enabled, but I don't think I have an OpenGL card).  Anyway, that Win2K machine is much better now.
--Scott
