Brake Manufacturer ??
Greetings...
Is anybody aware of a Brake Manufacturer which has a standard disc brake (mounted to the back of a motor) with a shaft sticking out the back side ?
I need to put an overspeed device on that shaft...and the arrangement which I have prohibits me from placing it anywhere else.
Also, the brake can not be aluminum nor cast iron (nodular iron/ductile iron/spheroidal iron is acceptable).
Thanks for any help !
RE: Brake Manufacturer ??
http://www.cjmco.com/
Barry1961
