Making LISP place "DWGMANE" into an attribute value?
Hi everyone!  I am returning to AutoCAD 2002, after working 13 yrs with MicroStation.  Funny what one forgets about LISP when away for so long.
I am trying to write a routine that places sys vari "DWGNAME" into a block attribute value "DWG_NUMBER".  DBOR2D.DWG is the name of the title block.
I am familiar with the old LISP from Release 10 and I am trying to relearn LISP with AutoCAD 2002.  I have the extraction from the dwg file figured out...
(setq dn (substr (getvar "DWGNAME") 1 (-(strlen (getvar "DWGNAME")) 4)))
..but I am fighting with the proper code of inserting the dn variable into the "DWG_NUMBER" attribute.
Sorry for being long winded beginning this thread.  I am not looking for actual code, but more confirmation it can be done with LISP and directions to references on how to do it.
Thanks in advance,
George
RE: Making LISP place "DWGMANE" into an attribute value?
Hi...
(defun dwg-atributo (/ dn p-ins atributo)
  (setq    dn (substr (getvar "dwgname")
           1
           (- (strlen (getvar "dwgname")) 4)
  ) ;_setq
  (if (not (tblsearch "block" dn))
    (progn
      (setq p-ins (cadr (grread 1)))
      (vl-cmdf "_.-attdef" "" "DWG_NUMBER" "" dn p-ins 2.5 0)
      (setq atributo (entlast))
      (vl-cmdf "_.-block" dn p-ins atributo "")
      (prompt "\nIndique punto de inserción: ")
      (vl-cmdf "_.-insert" dn pause "" "" "")
    ) ;_progn
  ) ;_if
) ;_defun
(defun c:dwginsert ()
  (setvar "cmdecho" 0)
  (vl-cmdf "_.undo" "_begin")
  (dwg-atributo)
  (vl-cmdf "_.undo" "_end")
  (setvar "cmdecho" 1)
  (prin1)
) ;_defun
(prompt "\n*** nuevo comando DWGINSERT definido. ***")
(prin1)
SpeedCAD, thanks for the help!  I guess I didn't specify my concern correctly.
The attribute "dwg_number" exists in a block, "dref2d".  I just want to populate that existing attribute with the system var "DWGNAME".
George
How about using RTEXT
Command:rtext
Initializing...
Current settings: Style=SSF 2002-A  Height=1 1/8"  Rotation=0
Enter an option [Style/Height/Rotation/File/Diesel] <Diesel>: D
A empty dialog box will pop up.
Insert the following code into the dialog box.
$(getvar, "dwgname")
Charles S. Parnell
Southern Store Fixtures
