Embosed letters
Embosed letters
Can anybody tell me how to create an embossed letter/number on a surface in UG 17.
Is that possible?
Is that possible?
RE: Embosed letters
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: Embosed letters
step1:you need to write first text in dwg file using annotation editor.then you export that dwg file as cgm keeping polylines option on in the cgm export dialog box.
step2:you import that cgm file into you model file.the text will come as a polylines.you can then either move it or project it on your surface.this way you can use this text for creating machining path.you can even extude this text to have an embossed shape.
i believe this will certainly help you.
MANISH SHAH
CAD ENGINEER
TATA JOHONSON CONTROL & AUTOMOTIVE LTD
RE: Embosed letters
-Derek
DL Engineering Services
specializing in Unigraphics Design Consultation Services
www.dl-engineering.com
RE: Embosed letters
It's very simple to do with Pro/DESKTOP Express (free version). After that, you can export to IGES/STEP for any CAD system.
HTH,
VnPenguin
RE: Embosed letters
my only additions would be to keep an eye on the Font being used, we have always used 'POSTER' font to allow a fully enclosed profile when importing the CGM back into the Model.
Also the CGM will come back into the Model on the X-Y Plane so make sure that the WCS is orientated on the face required.
we also have some UDFs for adding lettering. configured to reduce stress raises after machining.
regards........... Gary
CAx Manager/Lead Design Engineer
Moog Controls Limited
