can't run CATIMP
can't run CATIMP
Hi.
I would like to run CATIMP utility in CATIA 4.2.2 on Unix, in order to extract model files from an EXP file on my HD. The problem is that I can't select the input file using "STRING" field because it doesn't find anything!! (And also I'm not sure about choosing between the sources "DISKETTE" and "TAPE_8MM"...).
Can somebody explain me the correct procedure?
Claudia.
Claudia.
RE: can't run CATIMP
I have not Catia 4.x at home
Don't forget choose the output directory for your model file.
HTH
VnPenguin
Thank you for your quick answer.
I tried to write the complete path of the file, but the field is very very small, only 8 characters. It looks like very strange...
Moreover it seems that I MUST choose between DISKETTE and TAPE_8MM before going further, but it's impossible to copy the file on a floppy (33 MB!!).
I'm starting to think that my program has some bug, I don't know...
Do you know if it's possible to open EXP files with Pro-E?
Claudia.
Wait until.. tomorrow
VnPenguin
I take a screenshot here:
http://users.skynet.be/ndq/tmp/CATIMP.png
File type => Must be MODEL
Input file => Full path to your EXP file
Output file => Catia Directory declaration for imported model
For CORPRJ & CORFIC tables, you can enter anythings (works with me).
HTH,
VnPenguin
