Parametric BOM
Parametric BOM
I am making a BOM (bill of material) or stocklist. Using repeat reagions and user defined parameters and filters to customize the stocklist. The problem is that when a component is removed the detail numbers (idx numbers) are all reasigned. I don't want to drive the table with a parameter of detail number because it could appear on more than one assembly. This problem of changing detail numbers is driving the purchasing department crazy. Has anyone found a work arround for this?
RE: Parametric BOM
To fix the Index #'s in a Repeat Region choose:
Table/Repeat Region/Fix Index
Pick the repeat region (the BOM in this case)
Pick the Rows that you want to fix the item# on.
If at a later time you delete a "fixed" item the number remains fixed until you "Unfix" it.
This should keep the items numbers from changing when you make additions or deletions from the assembly (we battled this at first too).
Bob Kerila, PE
RE: Parametric BOM
No. PartNumber
1 123.prt
2 456.prt
3 789.prt
5 111.prt
6 222.prt
7 333.prt
In ProE, I havent found a way to fix the index for the 7th part since there are only 6 parts, not to mention leaving the extra blank line in the list. Does anyone have a way to do this using repeat regions vs. typing in all the info into a standard table?
Steve Plichta, ME
