Self-priming pump
Self-priming pump
Hello all!
Has anyone expriences of APV Ws+ self-priming pumps? It seems to be too good to true in my case. We need a pump which can pump pigment slurries (clay,chalk,talk) and the problem is air. Screw pump is a good alternative, but dry running is problem with it. At a moment we have hose pump, but the hose does not last so long, the worst case was 80 hrs. Our capacity is 30 m3/h.
http://www.apv.invensys.com/Pumps/SelfPrimingPumps.htm
RE: Self-priming pump
Hope this helps.
saxon
We have also tried AODD, but the valves get jam all the time and I was quite frustrated kicking them to start again!!
Best slurry in town
http://www.chemec.fi/
A progressive cavity pump also seems applicable to your needs.
Look at www.seepex.com
Best regards
Morten
PS: Im not connected to seepex in any way expect as a customer
