CDG Relay spares
CDG Relay spares
CDG Relay spares
Picture a CDG relay case only, at the bottom of the case is a molded mono block that has ten connections for the AC and DC wiring.
I am trying to source these bakelite connection blocks, I do not need the copper connector strips that usually make up the complete unit but only the bakelite block with the ten metal screw inserts. (Know as knurls in the engineering world).
I need to know if anyone still makes these things in the UK and how much it would cost me to purchase these blocks (initially 100).
RE: CDG Relay spares
The CDG relays are still manufactured and marketed by
Alstom measurement and control
Palavaram Works
19/4 GST rd
Palavaram
600043
Madras
India
tel 91 44 236 8621
Fax 91 44 236 7276
RajT
Thanks for the info. Unfortunately I have no luck getting in contact with these people. What I need is an e-mail address.
Try this address
hodigera.anantharamu@tde.alstom.com
He is a manager in charge of manufacturing numerical relays there , but he might be able to help or at least put you throgh to the right person.
His e-mail is the only one I could remember.
Thanks to all, I had tried the Alstom website previously but with no luck. However Aakhrinaam's contact has now replied to me so I think I am sorted.
Thanks again
