ACAD Error message "invalid page fault" module AC1ST15.DLL
I have re-installed several times trying to fix this problem. When I click on the MDT6 or ACAD2002 icon (or try to start the program through the start menu)I immediately get this window message and cannot continue to load-up program.
Please advise if problem is known ????
"ACAD caused an invalid page fault in
module AC1ST15.DLL at 017f:65fe1e3b.
Registers:
EAX=00000000 CS=017f EIP=65fe1e3b EFLGS=00010246
EBX=bff77716 SS=0187 ESP=00dcf888 EBP=00dcfa54
ECX=00000000 DS=0187 ESI=00ef0440 FS=0e7f
EDX=bff7024c ES=0187 EDI=00000001 GS=0000
Bytes at CS:EIP:
8b 10 8d 4e 04 8d 7e 14 89 11 8b 50 04 89 51 04
Stack dump:
00000001 00ef0530 00ef0db0 64616f4c 7262694c 41797261 bfbebd00 c3c2c1c0 c7c6c5c4 cbcac9c8 cfcecdcc d3d2d1d0 d7d6d5d4 dbdad9d8 dfdedddc c3c2c1c0 "
-Mark Scatoloni
RE: ACAD Error message "invalid page fault" module AC1ST15.DLL
see:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2893426&linkID=2475323
and download the updated file.
I think you use win Me or 98.
Bye
