Propeller Wake Theory
I was wondering if anyone out there had any practical experience with propeller or fan testing. My question is regarding the momentum theory of wakes. Using this theory it can be found that the air velocity in the wake region is double that at the propeller. Unfortunately, the tests that I am running on a ducted Multi-Wing propeller indicate zero increase in speed in the wake region.
I am curious to know whether this is a common divergence from theory.
Any thoughts?
Any thoughts?
RE: Propeller Wake Theory
Half the CHANGE in velocity happens ahead of the prop, the other half CHANGE occurs aft of the prop. Tests confirm the theory rather well.
Perhaps this is where the difference lies. My propeller is tested at static cnditions. There is no forward velocity.
STF
