ReplaceComponents Macro
I am simply trying to write a macro that will replace components in an assembly.  I tried recording a macro and doing some 'reverse engineering' on it but I keep on getting an error.  Here is the code I am using:
Set Part = swApp.OpenDoc4("C:\Program Files\SolidWorks\data\Templates\DMAssembly.sldasm", 2, 0, "", longstatus)
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID("DM1-1@DMAssembly", "COMPONENT", 0, 0, 0, False, 0, Nothing)
Part.ClearSelection
Part.ReplaceComponents "Some File Name", "", False, 0, True
Thanks in advance for any help.
RE: ReplaceComponents Macro
OpenDoc6: you need to have defined variables in place in the last two options to catch errors.
No need to "Set Part = swApp.ActiveDoc" is you already have the part object from using OpenDoc6
Try selecting using AssemblyDoc::FeatureByName
Good and evil: wrap them up and disguise it as people.
I tried that and it gave me the same error.  Ignore the opendoc6 for now, try to record a macro that will replace a component in an assembly (if you dont mind!).  I keep on getting that same error which tells me that i have the worng number of arguments, but it is a direct recording from SolidWorks so I dont understand.  Thanks for your help.
From the Help, I only see 4 arguments. You are passing 5.
retval = AssemblyDoc.ReplaceComponents ( fileName, configName, replaceAllInstance,  reAttachMates )
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
There we go!  Thanks, I don't understand why SolidWorks added the 5th condition, but it works now.  Thanks for your help/
