Size / Colour of Dimensions in Part Sketch Mode
Is there any way to increase the font size & alter the display colour of the dimensions when creating / modifying sketches in Part Mode?
RE: Size / Colour of Dimensions in Part Sketch Mode
What version of Solid Edge are you running?
Try going to Style... under the format menu and adjusting the dimension style(s) you are using in the profiles/sketches.  The text height and arrow size as well as much more is controlled there.
I asked what version you're running because the graphic display of some entities has changed throughout revisions because of the way dimensions and contraints were sized when zooming a profile.
--Scott
For some pleasure reading, the Round Table recommends FAQ731-376
