Drawingview dimensions
Hi everybody I try to get the dimensions of a drawing view , this is the code I am using it comes from the automation guide, would anyone try it and tell me if he /she can get these dimensions it is impossible for me:
Dim oXY(4) As Double
ViewToWorkOn.Size oXY
Xmin = oXY(0)
Xmax = oXY(1)
Ymin = oXY(2)
Ymax = oXY(3)
I have replaced ViewToWorkOn by the name of the view which interests me.
I have the following error:
"Fonction ou interface est mentionnée avec restriction ou la fonction utilise un type Automation non géré par Visual Basic" which could be translated by "Function or interface is badly called or the function uses an automation type unknown by VB"
Thanks for any help.
Bye
GaP.
Xmin = oXY(0)
Xmax = oXY(1)
Ymin = oXY(2)
Ymax = oXY(3)
Bye
GaP.
