IDEAS F4 BUTTON DOES NOT WORK
I have a question. When trying to use the F4 button to square up the view of my IDEAS model, a box pops up stating "F4-XYZ Rotate Triad Only" but it does not square up the model. How can I fix the F4 button to square up the view of the model.
thanks in advance!
thanks in advance!
RE: IDEAS F4 BUTTON DOES NOT WORK
VnPenguin
If it is not working for wireframe images either then it sounds like you've changed the mode on the function keys.
Hold down F6 and move the mouse up and down, selecting Mode 1 (the top selection), then release F6. Should work now
HTH,
VnPenguin
