rectification column ( Packed Column) design for methanol - water
I want the design of the packed column for rectification of the methanol water system having composition ranging
Methanol 50 % to 60%
WAter    50 % to 40%
desired purity of methanol after the rectification is above 90%.
RE: rectification column ( Packed Column) design for methanol - water
You can find your information in the McCabe/Smith/Harriott book called Unit Operations of Chemical Engineering.  There is a section on Packed Columns that contains step by step procedures.
