CATIA 4.3.2 hpgl2 problem
How do you stop CATIA's hpgl2 plot program from setting the plotter into it best mode of operating. There is no option for changing this. No matter what the plotter is set to, Catia puts in the best mode and its slow.
RE: CATIA 4.3.2 hpgl2 problem
This can be done by the following script:
cp $CATOUT $CATOUT.orig
cat $CATOUT | fold -w 80 >/tmp/catout.$$
head -1 /tmp/catout.$$ | sed 's/QL100//g' >/tmp/catout.$$.ok
tail +2 /tmp/catout.$$ >>/tmp/catout.$$.ok
cp /tmp/catout.$$.ok $CATOUT
Call this script from your plot_cfg file before sending the hpgl2 file to the plotter.
Thank you many times marktwain .
mm06905
