Layer manager buttons
i have this macro that i used in ACADr14 to manage layers i need to get it to work with R2000 .....can anyone help
Example
clayer electricDIM;layer on 35*,*electric*;;layer off 45*,46*,47*,*drain*,*water*,200DIM*,*item*,200BAS*,*furn*,*marr*,*equip*,*shelf*,*special*,*hvac*,*steam*,*gas*,*area*;;
RE: Layer manager buttons
instead of using "layer" command use "-layer" command
the "-" will suppress the dialog box.
this makes a layer current and turns some on and some off,
do you use the layer manager that comes with express?
^C^Cclayer electricDIM;-layer on 35*,*electric*;;-layer off 45*,46*,47*,*drain*,*water*,200DIM*,*item*,200BAS*,*furn*,*marr*,*equip*,*shelf*,*special*,*hvac*,*steam*,*gas*,*area*;;
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
