Coupling grease
Coupling grease
Coupling grease
Does anyone have any recommendations for coupling (gear type) grease for a variable speed aplication? The shaft speed could range anywhere from 300 rpm to 3000 rpm for any lenght of time.
RE: Coupling grease
On 50kW traction motor couplings we used Kluber:
http://www.kluberna.com/
- sorry, can't remember the grade but I'm sure they can suggest something.
RE: Coupling grease
Suggestion: Visit
http://www.directindustry.com/
click on Product Search and enter Gear Coupling and click Go.
etc. for more info from the gear industry since the gear may also have impact on the type of grease
Also, visit
http://www.exxon.com/USA-English/Lubes/PDS/NAUSENGRSEXHighSpeedCouplingGrease.asp
http://www.prod.exxon.com/exxon_productdata/lube_encyclopedia/grease.html
http://www.prod.exxon.com/exxon_productdata/lube_encyclopedia/g.html
http://www.prod.exxon.com/exxon_productdata/lube_encyclopedia/flexible_coupling.html
(for fairly stiff grease)
etc. for more info
RE: Coupling grease
There is an EPRI Guide which lists some options for couplings:
Chevron Coupling
Exxon Ronex Extra Duty*
Falk LTG
Mobil Mobilux EP 111
Texaco Coupling
It looks like all the big guys can offer you something as long as you tell them the application. One thing unique about coupling greases is they need to resist separation under centrifugal force.  We have seen first hand the effect of using general purpose (non-coupling) grease on gear coupling... not good.
RE: Coupling grease
Thanks, all. I know the higher the RPM, the higher the NLGI #. This application will run at both low and high RPM, so I'll likely use a #1.
RE: Coupling grease
I know FINA (now part of TotalFinaElf) had a grease called Fina Marson EPL1 which was specifically designed for use ingear couplings. Recommended by ESCO Gear couplings as well. Used it in SA with god results.
Lester Milton
Telford, Shropshire, UK
RE: Coupling grease
Suggestion: The coupling grease good for high and low RPM should be preferred.
