On-Line KMnO4 concentration monitoring
I am looking for an instrument or method to monitor the concentration of 3 wt % KMnO4/H2O solutions on-line for a scrubber application. I would like to automate the process to inject the concentrated KMnO4 solution when the feed concentration drops below 3%. I am considering conductivity but since it is not selective I will have to make assumptions about TDS.  Another method I have found is automated titration, which is expensive. Does anyone have any other suggestions?
RE: On-Line KMnO4 concentration monitoring
ORP should do the trick. Several suppliers are available depending on the severity of your service.
