Question from a newbie to FEA
Hi
I am a relatively new user of FEA. I am using MSC Nastran for windows.
I am working on a solder joint modelling. As a first step I have picked a very simple model, to learn the technique to solving a joint.
The model consists of a lead-tin plate sandwiched between two copper plates. I am assuming a perfect bonding between the plates.
I am loading the part in tension.
I have checked for coincident elements.
When I run the analysis, I get fatal errors. The number of fatal errors is always equal to the number of coincident points.
I understand I have to connect the coincident nodes. But I don't know how to do it correctly.
Any help in this will be appreciated. Are there any articles that tell how to analyze bonded structure?
Thanks in advance.
RE: Question from a newbie to FEA
You should merge the coincident nodes on the interface.  Otherwise, you will need to connect them using rigid elements.
There is quite a lot of literature on bonded joints.  You might want to check the Journal of Composite Materials (ASME).  Most of the bonded joint problems were solved in the early-1980's.
pj
