constrained pipe wall buckling
It will be grateful to you if you clarify the doubt as given
Below.
Whenever cross-country pipe crosses roads/tracks, it is going through a culvert. Actually, pipeline is completely
buried at culvert locations and in those cases soil and pipe couple together to resist buckling forces. These buckling forces are depends on the stiffness of pipe and soil. In case relative stiffness between pipe and soil at
Culvert location causes buckling at proceeding horizontal pipelines. Is it require to put restraints at culvert locations if yes what special type of support to be used
to overcome buckling effects. Is there any effect in buckling if a use 30 deg 18d bend (6 inch fuel gas pipe) in place of 45 deg 5d bends? Kindly reply.
P.Padmanaban
RE: constrained pipe wall buckling
