Dimension in an assembly
I want to dimension parts in an assembly to get the distance of parts at different levels but have the dimension lie on one plane. Right now SW gives me a point to point dimension. Acad can do this with snaps.
RE: Dimension in an assembly
In a drawing the dimension may be hidden by a part or something, maybe the right view shows the parts more visible. So pick the dimension hold the shift key down drag the dimension to the other view and now you should have your dimension in the right view.
I hope I have understood you correctly, and I hope I have answered this to help your need,
Scott Baugh, CSWP
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
