115/230v electric motor wiring
I nave an electric motor I would like to change the wiring on. That is, from 230v to 115v. Following are the motor specs(from the plate on the motor). I am pretty sure it was on an A.C. unit blower fan. I plan on using it to power a "squirrel cage" type blower fan for a shop fan.
Any help you could give would be helpful.
Thank You.
Joe
Mfg. is G.E.
a.c. motor thermally protected.
mod#5kc38rn4x
hp3/4
hz60
v115/230
rpm 1725
code L
A11.6/5.8
sf 1.0
fr 56
amb 40c
insul class b
time rating is cont.
ser no HND/
stk c138
Thank You.
Joe
Mfg. is G.E.
mod#5kc38rn4x
hp3/4
hz60
v115/230
rpm 1725
code L
A11.6/5.8
sf 1.0
fr 56
amb 40c
insul class b
ser no HND/
stk c138
RE: 115/230v electric motor wiring
Other than that, the manufacturer should be able to provide it.
Visit
http://www.ge.com
http://www.geindustrial.com/cwc/products?famid=23&SMSESSION=NO
etc. for more info
