Dimensioning in Solidworks
I know how to create a new dimensioning in a Drawing, that much is easy. What I would like to know is how to show a hole call out for a hole that was created in the part mode. I have been calling them out manually but would like for the dimension to appear already formatted with tap size, depth, coutbores, etc. automatically. Any Suggestions?
regards
regards
RE: Dimensioning in Solidworks
1. Hole wizard to create the hole.
2. If making the hole manually in a part from a circle in a sketch, you can still add all the annotations, GDT, etc. to the circle dimesion in the sketch while you are designing.
3. Insert model dimensions (and notes, etc.) in your drawing views. (Then the callouts will show up). You might want to do this by manual selection rather than globally this manually.
Look it all up in the help and give it a whirl.
Of course, I'm assuming you also know that you can add all the annotation stuff to dimensions and change their format in a DRAWING using their properties?
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
I feel that I have exhausted the help option.
Any other ideas? Thanks for all the responses by the way.
It just seems like there should be an easy way to display all the informaiton inputed into the hole creator(whether it be for couterbores or tapped holes) in the drawing automatically that follows some dimensioning standard format. Am I expecting too much from Solidworks?
Try editing the calloutformat.txt file under your SolidWorks directory.
But what you may be looking for is right click the hole dimensions and select display options and select define by hole wizard... if there is more info you are trying to add to the call out, then you may need to customize the hole call out file.
I hope this helps you rust dog, I had a hard time fully understanding what you were asking... But it is probably just me, I am having brain fade real bad today..
I have modified the calloutformat.txt file located in C:\Program Files\SolidWorks\lang\English
Give that a try. Remember to keep a copy outside the SolidWorks directory. Each upgrade will over right the file.
Bradley
