smart fastener recurring problem
SW2003 sp3.1
On several assembly I have created I have inserted smart fasteners.
From time to time (not knowing what causes the problem) I see the following error on rebuilds...
Smart Fastener1: Warning: Hole series has changed. Please verify that current fastener is correct.
It's a pain because I have to right click on the fastener and "mark up to date" or verify by opening the smart fastener dialog and confirming my fastener selection.
Is this a known bug or am I doing something wrong?
DG
DG
RE: smart fastener recurring problem
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
It happens if I don't change any parts and simply rebuild??
DG
One thing I did see that could cuase this problem from time to time is if you edit the surface the fasteners were originally placed onto... Change the shape. make any cuts or extrusions to the surface. This may not be what is actually causing your problem, just something I noticed during my assemblies and trying to use smart fastners.
I hope this helps,
Dale
Just a thought...
