right mouse button problem acad 14 in win XP
I'm using autocad 14 on a windows XP computer (laptop).
The problem is that I can't use the right mouse button to enter a command. EX. If I want to fillet an part and want to exit the command (with the right mouse button) nothing happens. So I have to push the escape button. If I do this I will exit the active command of course.
Is there anyone who knows a solution to this problem or can't the problem be solved at all and do I need to Buy a new Autocad program?
I use a compaq mouse on a presario 700 laptop with win XP. The right mouse button on my synaptics touchpad doesn't work either.
I thank everyone for their help.
RE: right mouse button problem acad 14 in win XP
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
