Sheetmetal bending help
I have a part that has several 'donuts' linked with tabs.
The part is .002 thk. How can I bend the part so that the tabs are bent with the 'donuts' stacked alternating on top of each other at certain distance between them?
thanks you
thanks you
RE: Sheetmetal bending help
Jon
jgbena@yahoo.com
Jon
jgbena@yahoo.com
_/---\_ _/---\_
I would start off sketching like above, then cut-away the material required to make your connected donuts, then Insert>Bends.
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
___
|__
___|
|__
___|
After meswsing with it for a while....
I created a solid of one donut with parts of tabs 180 deg apart, then added a hem to one of them. Then created a second solid like the first one based off the hem surface. Then a third hem off the other tab and so on...
When I click on unfold..WOW!
thanks everyone.
