Save as a PDF - anyone seen this?
I just noticed in SP4 that we can now save to a PDF file. Maybe this was in SP3.1 but I just noticed it. I don't have 3.1 installed anymore or I would test it.
Just and FYI for all of you that need to save as a PDF.
Best Regards,
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
RE: Save as a PDF - anyone seen this?
Scott Baugh, CSWP
FAQ731-376
I have SP4 but do not have this option. Do you have Adobe installed on your computer?
Regg
Weird!! I'm using 2003 SP4.0 and there is no selection "save as PDF" in my Add-Ins. I have Adobe Acrobat 5.0 installed on my computer, so I have a "send to distiller" selection in my printer window. I wonder if that has something to do with it being missing in the add-ins. I do have both "PhotoWorks" and "PhotoWorks Release 2" listed in my add-ins, but if I click on "PhotoWorks" it tells me it cannot load because it is missing a component. Why is it in the list if it is not there?
Timelord
I didn't think that because I installed PR1 that it would have an effect on my other SW versions, but it does. If you DL and install SW04 PR1, you will get this option in all other versions of SW.
Works pretty darn slick too.
Timelord,
The reason you can't pick the orinial PW is because after 3.1 PW became obsolete. It's only in there because of a .dll that is still in the SW directory. You could try removing the lworks.dll and see if that takes it out. You have to restart SW though.
Once you install SW04 at final release you won't have PW anymore.
Best Regards,
Scott Baugh, CSWP
FAQ731-376
Still, for day-to-day publishing, it should be great.
Jon
jgbena@yahoo.com
I have read (05 Aug 2003 issue of PC Magazine) that PDF995 creates larger than normal PDF files. Do you find that to be true? Have you used any other PDF convertors?
Regg
I do like the ability to "package" multiple documents by appending to the last document.
It works good, except for the part that says "An unknown error occured during the creation of the PDF file". I tried it in SW2003sp4 and SW2004sp3(pr1). Both the same.
I only get the message when trying to save (SaveAs PDF) parts, assemblies, or drawings. All the other files works fine
Mr. Pickles
Jon
jgbena@yahoo.com
At 300 dpi, the largest file sizes are about 130-140KB.
Remember...
"If you don't use your head,
your going to have to use your feet."
Curious - where did you get SW2004 SP3 (PR1)
Scott Baugh, CSWP
FAQ731-376
My temp is clear or empty or whatever.
I assume you are asking me where I got it. If you are, perhaps you are confused because I mistakenly typed SP3 instead of SW2004 Beta 3 (PR1).
Anyway, PDF runs, the progress bar gets to the end and the error pops up. Everytime, in SW2003 or SW2004.
Mr.Pickles
