Multiple Viewports - Dissapearing Contents
I have had problems w/ several AutoCAD 2000 drawings containing multiple viewports. When the drawing is first opened, all the layers that should appear based on saved layer states in the layermanager are visable. A plot preview also shows correctly. After plotting however, all orsome of the viewport contents do not plot. Repeating the steps now shows the incomplete viewports. Typically these drawings are composed of several x-refs in model space. I am careful to have layer zero current when insertting the x-refs. Most of the x-refs w/ the exception of the title block & border are overlayed. Any help that can be provided would be great.
RE: Multiple Viewports - Dissapearing Contents
1. Make sure that Visretain is set to 1.
2. Autocad 2000 has a maximum number of viewports...I think the number is 64. In version 14 the number is 16.
3. You may be exceeding the capacity of your plotter. Check the RAM.
