machining plastic ABS POLYCARBONATE
What are the specifications to drill and tap ABS and Polycarbonate???
The task to do is drill and tap  5/16 NC  a trought hole about 10 mm thick.
Some pieces are just drilled and need only to tap.
Other are with no holes so I think to use a drill-tap tool.
I need to known
Cuting speed .
Tap and drill material
Its cuting angle and flutes.
RPM
Drill Feeding
Thanks in advance.
Pardal
