hole locations wood joists
Some building codes show locations for holes in wood
floor joists at different locations. One code showed holes only to be located within middle third of span, others showed only within outer thirds of span and some do not even show locations. Both 2" clear from top and bottom and D/3 for dia. WHICH WOULD BE THE BEST LOCATION
WITHIN ENGINEERING STANDARDS.
RE: hole locations wood joists
Peter von Buelow
Univ. of Mich. - TCAUP
