source of analog 4-Q dc drive controllers
Who still makes a conventional (analog NOT digital) 4-quadrant DC drive controller (for 480-3-60 input. It appears that the industry was very successfull in telling everybody that "it needs to be digital (= non-repairable, limited life expectancy, complicated start-up (300 parameters to set, in order to keep manufacturers field service personnel busy.
We have drive controller requirements (for high HP / 400 to 900 amp drives / shunt-wound )requiring simple speed control via armature voltage feedback.
Is there anybody (in the US) still making components for such drives (4-q front end speed / current regulator, SCR firing bord adaptable for the gating power of large SCRs.
I am interested in purchasing complete controllers (with or without the power SCR stacks)in chassis form (not enclosed for integration in our own system control enclosures.
(we know Saftronics DC12 (30 year old design, the single controller board is way too large, very outdated with 741 op amps).
I would appreciate supply source suggestions
RE: source of analog 4-Q dc drive controllers
Be aware that the people that study market trends report that the DC drive market is shrinking by about 3% per year, the AC VFD is overwhelming all of the traditional variable speed drive technologies.
It seems that they still have the capability but it will be custom with an appropriate price. Goog luck.
Bardac does not cover the high current units required.
We found Brook Solutions in Kitchener, Ont. (formerly SAF)
They make DD312 drives up to 800 HP. The unit has an analog front end (regulator) coupled to a digital firing card. They call it "hybrid".
http://www.drivesurvey.com/index_home.html
since the posted one does not open
