Problem with pre-tensioned bolt
hi,
I`d like to perform a nonlinear analysis in ABABUS with pretensioned bolts (made of solid brick elements). The model was created with I-DEAS-Preprocessor.
I defined a pre-tensioned section and a pre-tension node for each bolt. The pre-tension nodes are not attached to any element in the model, they are free in space.
In a first step I applied a defined pre-tension force (CLOAD) by means of the pre-tension nodes.
And now my problem, when I run the analysis, a "numerical singularity solver problem" occured at one of the pre-tension nodes. I assume a rigid body motion in the free DOF of the free node. I`ve read the ABAQUS manual a thousand of times, but I didn`t forget anything. No additional boundary condition is necessary in the first step when I use the CLOAD command. But then a rigid body motion of this node will cause an solver problem..
Has anyone any experiences with pretensioned bolts?
Below I added some lines.. please help me..
*PRE-TENSION SECTION, SURFACE=PRE_TENSION_SURF01, NODE=1000001
*PRE-TENSION SECTION, SURFACE=PRE_TENSION_SURF02, NODE=1000002
*PRE-TENSION SECTION, SURFACE=PRE_TENSION_SURF03, NODE=1000003
*PRE-TENSION SECTION, SURFACE=PRE_TENSION_SURF04, NODE=1000004
*STEP,NLGEOM
*STATIC
0.5,1.0
*CLOAD,OP=NEW
1000001,1,18000.
1000002,1,18000.
1000003,1,18000.
1000004,1,18000.
*END STEP
*STEP,AMPLITUDE=RAMP,NLGEOM,INC=100
*STATIC
.2,1.,.001,.2
*BOUNDARY,OP=MOD,FIXED
1000001,1,1
1000002,1,1
1000003,1,1
1000004,1,1
*END STEP
*STEP,NLGEOM
*STATIC
0.5,1.0
*CLOAD,OP=NEW
1000001,1,18000.
1000002,1,18000.
1000003,1,18000.
1000004,1,18000.
*END STEP
*STATIC
.2,1.,.001,.2
1000001,1,1
1000002,1,1
1000003,1,1
1000004,1,1
*END STEP
RE: Problem with pre-tensioned bolt
Brad
When I run the analysis without the pre-tension definition, there is no problem.. but when I add these lines above, I got the solver problem every time.. but is the answer to constrain the only DOF of the pre-tension nodes in step 1? I don`t think so..
Without getting into a lot details, I suspect if everything else in your model is kosher, this will work.
Brad
Is the bolt free, i.e. has contact been modelled between the bolt-head & component etc. and the frictional forces generated assumed to remove the rigid boby motion. I have had this problem previously analysing bolted asemblies, use soft springs in the inital preload step. These can be optionally removed in the 2nd step (i.e. *MODEL CHANGE) when the frictional forces are fully developed.
Barry
You may wish to contact your local ABAQUS rep. They will sometimes run your deck and tell you how to debug it.
Best regards,
KF9RI
Does anybody know what is the philosophy of the PRE-TENSION? How is it formulated in the solver? I am quite confused with something in the manual: " When a pre-tension node is not controled by using the *BOUNDARY option, make sure that the components of the structure are kinematically constrained; otherwise, the structure could fall apart due to the presence of rigid body modes?". What does it mean "to FALL APART"?
thanks
Gary
Without getting into the math, the easiest way to conceptualize it is a cutting-plane across the pre-tension surface (or through the beam). This then "splits" the bolt into two parts. The reference node enforces constraints consistent with axial strain/deflection (if everything is done right).
My suggestion about a dummy step and boundary comes out of this realization; there is a potential for one side of this "split" bolt to be unconstrained. Please do not take this description completely literally; it's intended to basically the phenomenon.
Brad
