Sample valve for high pressure system
Dear all,
I want to take product quality samples from a piping system where pressures go up 100 bar (at 90 gradC). Does anybody has experience with fluid sampling valves / methods at high pressures? How can I take a save product sample?
Thanks!
MVD
Thanks!
MVD
RE: Sample valve for high pressure system
we used Sentry equipment -- I am familiar with it ( http://www.sentry-equip.com/ )
there are other manufacturers available, do a search here: http://www.thomasregister.com/SearchListing.aspx?pn=19572205&search_type=product&search_string=coolers&sid=0308060855278800009631BW1&uuid=TRGuest
In particular, their isokinetic samplers are industrial leaders in comparison to others in the field. The trade name "Tru Cut" comes to mind.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
They make sampling (analyser)valves which can be used even at inlet pressures 6000 psi (approx.400bar)and downstream pressure as low as atmosperic.
Danial Quigley
International Regional Sales Manager
Sentry Equipment Corp.
856 E. Armour Road
P.O. Box 127
Oconomowoc, WI. 53066, USA
Phone 262-567-7256, X105
Fax 262-567-4523
or
Rob Lemke
Inside Regional Sales Engineer
T: 262-567-7256 x120
F: 262-567-4523
On my current project we have had good success with a double block and bleed sample probe made by Alco Hi-Tek.
The company website for Alco is:
http://www.alco-valves.com/AlcoGroup.htm
Thanks !
As some one mentioned above double block and bleed I would make it more specific of my choice; a valve based on 2 valve desgin, consiting of two shut of valves (block valves and one test porst); its not a three valve manifold;
its available from Parker hannifn; will realy work well on your budget!! Post your choice later on..
http://www.texassampling.com/
YZ and others make sample probes. YZ is now owned by Milton Roy http://www.yzsystems.com/corp/details/0,3708,CLI1_DIV41...
John
